Easy VPN in Mesh setup
Jan 24th, 2008
hi I have 4 Easy VPN sites which are terminating on ASA fire wall and we need access from all VPN sites to each other currently all are Easy VPN sites is it possible in Easy VPN ?/
ajagadee Fri, 01/25/2008 - 22:17
  • Cisco Employee,
Yes, this should be possible using
The feature you are trying to enable, permit traffic to enter and exit the same interface, to permit two or more spokes (VPN clients or hardware clients) comunicate to each other, is only for 7.x version.
Please refer the below URL for details:
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml
Arul
** Please rate all helpful posts **
ismartnets Mon, 01/28/2008 - 21:00
Dear Sir,
Thank you ... also provide us an example with Router, we want to integrate site using Router acting as EzVPN in mesh setup pl find below is the show version
Cisco IOS Software
, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(9)T5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 16-Aug-07 14:30 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
MOALAJAHAUH uptime is 1 hour, 5 minutes
System image file is "flash:c1841-advipservicesk9-mz.124-9.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1841 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FCZ112310L9
2 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
