Warning message
Lan-to-Lan Over NATted connection
Jan 24th, 2008
Hi all.
Anyone has successfully configured a lan-to-lan between two pix, both with private address on outside, statically natted on ISP router?
Pix1----R1-----Internet-----R2----Pix2
Pix1 has IP add 10.1.1.1, on R1 there's a nat rule like
ip nat inside source static 10.1.1.1 88.10.1.1
Pix2 has IP add 10.2.2.1, on R2 there's a nat rule like
ip nat inside source static 10.2.2.1 89.20.1.1
Till now I've always used static ip configured on outside interfaces; or one pix with static ip and the other configured like easy-vpn-client with net-extension mode.
In this case I don't have any public ip, excluding the one on router.
Daniele
Overall Rating: 4 (1 ratings)
ajagadee Thu, 01/24/2008 - 06:53
  • Cisco Employee,
Assuming that you want to encrypt the LAN behind the Pixes, this should work as far as the IPSEC peers are 88.10.1.1 and 89.20.1.1 and you not blocking UDP Port 500 and Protocol 50 on the router and Pix.
Arul
** Please rate helpful posts **
dimensyssrl Thu, 01/24/2008 - 08:17
thanks for your reply
I thought that can be a problem, because the pix use its true ip (private ip) to encrypt, and the packet encrypted is modified in transit by nat device
Is it not a problem?
ajagadee Thu, 01/24/2008 - 08:42
  • Cisco Employee,
In the above scenario, lets say the LAN 1 Behind the Pix 1 is 192.168.1.0/24 and LAN 2 Behind the Pix 2 is 192.168.2.0/24. And you want to encrypt the traffic between LAN1 and LAN2 using Pix 1 and Pix 2.
Traffic Flow from Pix 1 to Pix 2
Now, the source and destination IP Address will be encrypted, that is 192.168.1.0/24 and 192.168.2.0/24 but the encrypted packet's source IP will be 10.1.1.1 and destination IP will be 89.20.1.1. When this packet hits R1, the router will translate the source IP of the packet to 88.10.1.1.
Traffic Flow from Pix 2 to Pix 1
Now, the source and destination IP Address will be encrypted, that is 192.168.2.0/24 and 192.168.1.0/24 but the encrypted packet's source IP will be 10.2.2.1 and destination IP will be 88.10.1.1. When this packet hits R2, the router will translate the source IP of the packet to 89.20.1.1.
So, I dont see an issue with this configuration.
Arul
srue Fri, 01/25/2008 - 07:38
  • Blue, 1500 points or more
make sure nat-t is enabled.
crypto isakmp nat-traversal
also, allow udp/4500 to each pix from the other pix'es public IP.
