Recommendation needed for Pix OS upgrade path please
Jan 24th, 2008
We have 2 x 525 with PIX Version 6.3(3)132. ASSUMING ver 8 is the "best" (ie most secure) version - do we need to upgrade to ver 7 first or can we go straight from 6.3 to 8 (subject to possible additional memory requirements) appears to state that you need to go to 7 first - though this is unclear. Also I make the radical assumption that 8 is more secure and "better" than 7
Overall Rating: 5 (2 ratings)
m.sir Thu, 01/24/2008 - 04:41
The minimum software version required before upgrading to PIX Version 8.0 is PIX Version 7.2.
The minimum software version required before performing an upgrade to PIX Version 7.2(2) is PIX Version 7.0. If you are running a PIX version prior to PIX Version 6.2, you must first upgrade to PIX Version 6.2 or PIX Version 6.3 before you can begin the upgrade to PIX Version 7.0.
so I guess you need follow path
6.3 -->7.0--->7.2--->8
consult following links for mor info
hope that helps rate if it does
