need help with department attendant console
Jan 24th, 2008
I have cominication with the callmanager, but cannot see anything on the client, need some extra configuration apart from the manual
Abdulbaseer Mohammed Fri, 01/25/2008 - 06:19
Sounds like client trouble. Is this happen on any other console as well?
Did you try re installing and re configuring? for specific help you may want to give bit more details.
Good luck.
