01-24-2008 05:43 AM - edited 03-05-2019 08:40 PM
Hey Guys,
Well i'm stumped. After turning on debugging, running wireshark, i'm lost at why this is happening. Basic setup, just must not be seeing something.
Here is my small home network running cisco devices (trying to practice for my ccna)
1) Cisco 1721 Router (192.168.1.1)
2) Cisco 2950 Switch (192.168.1.2)
3) Laptop (192.168.1.10)
Everything is on a /24 subnet.
What is odd here is when I try to ping an ip address on the internet from my laptop, I don't get a response. I also can't view webpages or have any contectivity outside my router.
However, if I ssh into my router, I can ping google.com no problem, and i can do pretty much anything. So I know there has to be something on my router that is stopping anything on my network to be going out.
From my laptop, I can ping:
192.168.1.2 (Switch)
192.168.1.1 (Router)
64.19.14.13 (ISP Static IP assigned to me)
I can't ping:
72.14.207.104 (Google.com)
show ip route:
206.53.49.0/32 is subnetted, 1 subnets
C 206.53.49.10 is directly connected, Dialer1
64.0.0.0/32 is subnetted, 1 subnets
C 64.89.19.19 is directly connected, Dialer1
C 192.168.1.0/24 is directly connected, FastEthernet0
S* 0.0.0.0/0 is directly connected, Dialer1
Solved! Go to Solution.
01-24-2008 05:46 AM
Chris
If you can access the router and from the router you can access Internet resources, then we can mostly rule out routing problems. My first guess is that you are not translating the addresses of your inside network as it goes through the router and to the Internet.
Can you tell us whether you are translating the addresses? Even better would be to post the config of the router.
Rick
01-24-2008 05:46 AM
Chris
Rick
01-24-2008 05:47 AM
Some sites do block icmp from the internet. I can ping the site with no issue, so i'm going to say it is an ACL issue. Are you allowing ICMP in your ACL? It would help if you post your config or at least your access-list.
01-24-2008 05:53 AM
Current configuration : 2629 bytes
version 12.3
no parser cache
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname mav
boot-start-marker
boot-end-marker
enable secret 5 <
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip name-server <
ip name-server <
ip cef
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
username admin privilege 15 password 7 1D091623282F
username user password 7 <
interface Ethernet0
description Physical ADSL Interface (Facing the ISP)
no ip address
no ip mroute-cache
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0
description My LAN Interface
ip nat inside
no ip mroute-cache
speed auto
full-duplex
no cdp enable
interface Dialer1
description Logical ADSL Interface
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <
ppp chap password 7 <
ppp pap sent-username <
ip nat inside source list 10 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.140 22 64.89.19.19 22 extendable
ip nat inside source static tcp 192.168.1.133 222 64.89.19.19 222 extendable
ip nat inside source static tcp 192.168.1.139 221 64.89.19.19 221 extendable
ip nat inside source static tcp 192.168.1.140 904 64.89.19.19 904 extendable
ip nat inside source static tcp 192.168.1.140 905 64.89.19.19 905 extendable
ip nat inside source static tcp 192.168.1.140 903 64.89.19.19 903 extendable
ip nat inside source static tcp 192.168.1.140 902 64.89.19.19 902 extendable
ip nat inside source static tcp 192.168.1.141 3387 64.89.19.19 3387 extendable
ip nat inside source static tcp 192.168.1.142 3390 64.89.19.19 3390 extendable
ip nat inside source static tcp 192.168.1.143 80 64.89.19.19 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
no cdp run
line con 0
exec-timeout 120 0
password 7 070
login local
stopbits 1
line aux 0
password 7 110
login local
line vty 0 4
exec-timeout 0 0
password 7 104
login local
length 0
scheduler max-task-time 5000
end
01-24-2008 05:59 AM
WHOOO hoo! Got it! Thanks for the hint!
Was missing:
access-list 10 permit 192.168.1.0 0.0.0.255
01-24-2008 06:00 AM
Chris
Thanks for posting the router config. I believe that the problem is an address translation problem. In your original post you identified the PC address as 192.168.1.10. There are some static translations, but not for the PC address. There is a dynamic translation but it references access list 10 and I do not see access list 10 in the config. I am guessing that this is the source of the problem. If you configure access list 10 to permit 192.168.1.0/24 I believe that it would work.
Rick
01-24-2008 06:01 AM
Add the following to your dialer 1 acl
access-list 121 permit icmp any any
access-list 121 permit icmp any any echo
access-list 121 permit icmp any any echo-reply
access-list 121 permit icmp any any packet-too-big
access-list 121 permit icmp any any time-exceeded
access-list 121 permit icmp any any unreachable
This should allow your to see the echo from the sites.
01-24-2008 08:33 AM
Chris
I am glad that we were able to help you to find the solution to your problem. Thank you for using the rating system to indicate that your problem was solved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read what successfully solved the problem.
The forum is an excellent place to learn more about Cisco networking. I encourage you to continue your participation in the forum.
Rick
01-24-2008 08:57 AM
I plan too ;) I just got my CCENT .. going the cisco track .. might have more questions in the future (or at least harder ones) ;)
