IPCC Script - Zero Out
Jan 24th, 2008
I am relatively new to IPCC scripting, and am still waiting on the proper learning material to arrive. In the meantime I need to add a zero out/time out option to an existing script. I can't seem to locate the proper object in the CRS editor to add a zero out/time out option. Any help would be greatly appreciated.
joepapesh Thu, 01/24/2008 - 18:32
I am not sure what version of IPCC you are running, but I am referencing IPCC Express 4.0(5).
Zero-Out Option - We utilize a "menu" item under the Media section of the editor. You just record a prompt that says "if you would like to transfer to an operator (or Voicemail) press 0 now." You do have to insert some silence after the prompt, so that the caller can press 0 before you put the call back on hold to play more music. If you want them to 0 out at any time during the call then I think you do the same thing however, your prompt has to include the recorded music, and the messages in a long audio clip (but I haven't ever done that).
Time-Out Option - You need to utilize the Get Reporting Statistic which is located under the IPCC Express drop-down. I populate the settings as follows to get the Current Wait Duration (time in queue).
Report Object: CSQ IPCC Express
Field: Current Wait Duration
Row Identifier: User Defined String Variable that identifies the CSQ
Contact: Triggering Contact
Result Statistic: User Defined Integer Variable that will capture the number of seconds.
Then I just utilize an If-Then to determine whether to keep them in queue, or dump them to an operator or voicemail.
I hope this helps,
afischer1 Fri, 01/25/2008 - 12:32
Thanks for all the help guys. I'm going to read through the documentation then try and make the changes myself. If I do run into problems I'll send you the script for advisement abdulbaseer.
Thanks again for the help.
Abdulbaseer Mohammed Mon, 01/28/2008 - 22:23
good luck. Its really not that hard.
Sorry I cannot send file bigger than 5 mb and I am lazy to zip.
