Eol or EoS for
Jan 24th, 2008
Hi All
I have a Cat 4503 running CatOS. I have just checked the website and know that supervisor card WS-X4013 is now EoL for Cat 4000.
Is it EoL also for Cat 4503?
1 1 2 1000BaseX Supervisor WS-X4013 no ok
2 2 48 10/100/1000 Ethernet WS-X4448-GB-RJ45 no ok
3 3 48 10/100/1000 Ethernet WS-X4448-GB-RJ45 no ok
Martin Parry Thu, 01/24/2008 - 07:28
  • Silver, 250 points or more
But you stated in your original post that your enquiry regarded the WS-X4013 SUP 2. These went EOS May 2005
Martin
qwertys21 Thu, 01/24/2008 - 07:35
Thanks Martin
It shows on my show mod
Is this the same as WS-X4013 SUP 2. This is really confusing as I need to be sure I am not saying a device is EoL when it is not.
So what I have is a Cat 4503 with
Mod Slot Ports Module-Type Model Sub Status
Is the
1 1 2 1000BaseX Supervisor WS-X4013 end of life?
Thank for your help.
ankbhasi Thu, 01/24/2008 - 07:40
  • Cisco Employee,
Hi Friend,
WS-X4013 is SUP 2 and WS-X4013+ is SUP2 Plus.
WS-X4013 only supports CATOS and is now EOL but SUP2+ supports IOS and is still supported on 4500 chassis.
What you have is SUP2 which is EOL.
Ankur
*Pls rate all helpfull post
FWIW, this is what a sh module looks like for a Sup II+ 4503
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE00000000
2 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE00000000
3 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE00000000
qwertys21 Thu, 01/24/2008 - 09:14
This is what I get on the show module on another Cat 4503 running IOS. Is this Sup or Sup II and is this EoL? It does not explicitly say Supervisor II+ like yours says.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE07350945
2 48 10/100/1000BaseTX (RJ45) WS-X4448-GB-RJ45 JAB080908KP
Martin Parry Thu, 01/24/2008 - 09:19
But it does say WS-X4013+ which is Sup2+. The SUP2 only runs CAT OS, wo the fact that you are running IOS is another indication you have a SUP2+ in that chassis.
Martin
qwertys21 Thu, 01/24/2008 - 09:36
Thank you. Now I can be sure of what I am saying. Thank ou very much
