CCM 4.1(3) MOH sound quality distortion
Jan 24th, 2008
I have problem with a cluster with four CCM servers. Every one of them is running CCM service but the one dedicated for MOH has only a few end devices and performance looks OK. We are experiencing bad sound quality from the MOH server.
Is there a reliable way to investigate and troubleshoot is the problem relayed to the server performance or something else? May I capture RTP streams from the MOH server and look at the achieved delays and jitters.
Please recommend me a technics to troubleshoot this if you have touched similar problems.
Thanks in advance.
z.zdravkov Thu, 02/07/2008 - 08:03
The problem isn't in the file 100% because sometimes the quality is good, sometimes bad. There is another reason. I can send you the files but they are the default files that comes with CCM. A kind of monitoring can help me.
Jaime Valencia Thu, 02/07/2008 - 15:11
  • Cisco Employee,
  • Hall of Fame,
    2011
you can use span session on a switch port and connect a PC with ethereal to capture the RTP stream and look into jitter and delay.
