DMZ NAT question
Jan 24th, 2008
I am configuring a new ASA with a DMZ for my web server. I need to have certain websites able to pass traffic to SQL servers on the inside interface and people from the inside able to hit websites on the web server, but I want to make sure that the IPs of the traffic being passed between the DMZ and the Inside are their actual IPs (not NAT'd). Do I need to create a 'no-nat' access list statement for this and place it in a NAT statement for the DMZ? Would the following work?
Inside is
DMZ is
access-list nonat permit ip
nat (dmz) 0 access-list nonat
nat (dmz) 10
global (outside) 10 interface
Overall Rating: 4 (1 ratings)
pjhenriqs Thu, 01/24/2008 - 07:33
I believe the access-list should be the other way around:
This will allow traffic from the DMZ to be exempted from the NAT translation when their destination is the inside.
To achieve two way traffic between DMZ and inside do:
access-list nonat1 permit ip
access-list nonat2 permit ip
nat (dmz) 0 access-list nonat1
nat (dmz) 0 access-list nonat2
and it should also have
global (dmz) 10 interface
HTH and please rate if it does.
acomiskey Thu, 01/24/2008 - 07:38
I don't think you can have 2 nat exempt statements for the same interface.
Another way of doing this is simply...
static (inside,dmz)
pjhenriqs Thu, 01/24/2008 - 07:46
My bad...damn copy+paste :)
What I meant was:
nat (inside) 0 access-list nonat1
Also, you can have two nat exempt statements that do not conflict (and that make sense) applied on the same interface. I have it in one of my configurations and working ok.
qbakies11 Thu, 01/24/2008 - 07:54
By acomiskey:
"Another way of doing this is simply...
static (inside,dmz)"
If I have this static statement in my config then I don't need to worry about bypassing NAT?
