WAAS: reestablish connection after break takes up to one our
Volker Janusch
Level 4
Level 4
in testing environment the time to establish the new optimization takes up one our. We disconnected one wae via shut-down of the redirect-interface. The edge wae is connected directly to the edge-router. WCCP-redirection works but the statistics for wccp traffic on the edge wae are all zero. The window for Statstics of the CM shows no optimization for this connection. We tested with copy of text-file.
I don't know wy.
Regards.
Volker
Manager DC-Networking, Automation & WLAN
Logicalis GmbH
7 Replies 7
Zach Seils
Level 7
Level 7
Volker,
Can you please provide some more information about your deployment? What IOS and WAAS versions are you using? Can you provide the output from 'sh ip wccp 61 det' and 'sh ip wccp 62 det' on the router?
Zach
Zach,
the edge router does not support the command sh ip wccp det.
I send this output from the core router.
WAAS-Version: 4.0.15.b.6
Core router
12.4(13b)
Core-Router#sh ip wccp 61 det
WCCP Client information:
WCCP Client ID: 10.131.100.2
Protocol Version: 2.0
State: Usable
Initial Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Assigned Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Hash Allotment: 256 (100.00%)
Packets s/w Redirected: 125191
Connect Time: 02:41:10
Bypassed Packets
Process: 238
Fast: 0
CEF: 5983
Errors: 0
Core-Router#sh ip wccp 62 de
State: Usable
Packets s/w Redirected: 112401
Connect Time: 02:41:44
Bypassed Packets
Process: 0
Fast: 0
CEF: 5568
Errors: 0
Edge-Router
12.2(46a)
Jan 24 14:31:15 MEZ: %WCCP-1-CACHELOST: Web Cache 10.131.100.66 lost
Jan 24 15:22:40 MEZ: %WCCP-5-CACHEFOUND: Web Cache 10.131.100.66 acquired
Volker
Logicalis GmbH
How often do you see those messages in the edge router logs?
Zach
Whensoever the redirect-interface or the Edge-WAE goes down and comes up.
Volker
Logicalis GmbH
Volker,
It's not clear to me what problem you are facing. Is WCCP redirecting traffic on both routers? What connection states, if any, do you see in the WAEs?
Zach
Zach,
the connectios statistiks of both wae are zero in the field "% Comp" and the customer can follow this with his applications. But the kind of optimization is displayed (dre, compression) for each connection.
Volker
Logicalis GmbH
Please provide the following output from the CLI of each WAE:
sh tfo conn summ
sh stat tfo pass
Zach
