config 16 T1
Jan 24th, 2008
I config the AS54 with 16 T1. it will receive "886" and "65" prefix.
do I need to config 16 dialpeer for 886 and config 16 dialpeer for 65? (total 32 dial peer). any work around to reduce the dial peer?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Thu, 01/24/2008 - 09:37
No, you use trunkgroups:
int serial x/y:23
trunk-group my-tg
dial-peer voice 866 pots
destination-pattern 866
trunkgroup my-tg
Then under "trunk group my-tg" you can optionally configure things like translation-rules, hunt scheme and more. Do "show trunk group" and you will see all what the lines are doing.
There is also a configuration for DP using alternate match patterns what would allow grouping 886 and 65 in a single destination-pattern, but probably is just confusing and not necessary.
