Mapping network drives after logging in to VPN
Jan 24th, 2008
We are having a problem where remote users login to their laptop with cached domain credentials using SSL VPN (the users are onsite but take their laptops home). Problem is they login to the VPN and their mapped drives don't work and they need to delete and remap their drives everytime they log in (we have to use FQDN to remap, example would be Jsmith1.anycompany.com). Any suggestions
Overall Rating: 4.7 (3 ratings)
rimbertr1 Mon, 01/28/2008 - 12:55
I don't have any experience with cached domain credentials using SSL VPN so I don't know if this is applicable but you may want to have them try logging in to the VPN before logging in to the machine (VPN Client->Options->Windows Logon Properties->Enable start before logon).
PaulWelc Mon, 01/28/2008 - 14:28
Thanks for the help but I'm using the Cisco AnyConnect VPN client and it doesn't have options. I think my old IPsec client had those options.
pengfang Tue, 01/29/2008 - 21:44
Hi, you can enable Start Before Logon (SBL) for AnyConnect client.With SBL enabled, the user sees the AnyConnect GUI logon dialog before the Windows logon dialog
box appears. This establishes the VPN connection first. Available only for Windows platforms, Start Before Logon lets the administrator control the use of login scripts, password caching, mapping network drives to local drives, and more. You can use the SBL feature to activate the VPN as part of the logon sequence. SBL is disabled by default.
1. Create user profile, then edit attribute, for example,settiing myprofile.xml file to true:
<?xml version="1.0" encoding="UTF-8" ?>
true
To disable SBL, set the same value to false.
You must also specify on the security appliance that you want to allow SBL. Take a look AnyConnect User manual,see the description in the section Enabling Modules for Additional AnyConnect Features(ASDM) or Enabling Modulesfor Additional AnyConnect Features (CLI) for a description of how to do this.
Pls rate if it helps.
PaulWelc Wed, 01/30/2008 - 12:43
Thanks pengfang, I think I'm getting closer to a solution. Only problem is the remote office is connected via site to site VPN. After hours and on the weekend they take their laptops home, to do work. So if I did the above it would work great for them remotely, but when they got back to the office it probably wouldn't work as they would be using the site to site.
pengfang Wed, 01/30/2008 - 23:26
Hi Paul,
To enable the UserControllable feature, use the following statement when enabling SBL at your profile.xml:
true
By this way, your remote user can enable SBL at home and cancel SBL at office.
MARK BAKER Wed, 08/27/2008 - 10:49
I'm having a hard time trying to figure out how the UserControllable feature works on Windows XP. I assumed it would work the same as the IPSec VPN Client where I could allow users to enable or disable the SLB option. I don't see where this can be enabled or disabled by a user with the AnyConnect client. And what does it mean by user settings are stored elsewhere? Where are they stored and how do you set them?
true
(Note in documentation for above line)
Any user setting associated with this attribute is stored elsewhere.
The above line works the same for me as the line below. I don't see the difference between the two. They both use SLB, I can cancel the SLB with either by clicking the x in the window, and I don't see how a user can enable or disable SLB on either. So, what is the difference?
I am hoping I am missing something simple here. Any help is greatly appreciated.
PS. I used "true" as well as "false" with the command and it still worked the same.
Mark
