Unity failover 4.2(1)
Jan 24th, 2008
Is it ok to do failover with the Primary as windows 2000 and the new secondary as windows 2003. I understand the hardware, Unity version,SQL Version must be the same but the Doc's don't clarify if the OS has to be the same.
Tommer Catlin Thu, 01/24/2008 - 10:18
  • Green, 3000 points or more
The OS should be the same as well. 1:1. I have not tried it with 2000 to 2003, but i would stay with the same OS, etc.
hwilms5575 Fri, 01/25/2008 - 07:07
Thanks for the reply- I did get an answer from TAC and they say should be no issues if one server is win2k and the other is win2003.
Tommer Catlin Fri, 01/25/2008 - 08:49
Wow! I did not think they would support this. Interesting. I know it's just SQL replicating, but Im suprised they supported this.
Thanks for the reply!
