WebVPN - Can't log in??
Jan 24th, 2008
I created a new group on my 3000 series concentrator called "WebVPNGroup".
Type is internal - I want to configure each user account locally.
I created a new user and associated him with the WebVPNGroup. I gave the user the same password as the group.
I enter the external IP to the concentrator and hit the WebVPN portal -- I enter the username and password, but get a login error. Here is what the log shows:
437 01/22/2008 13:22:13.450 SEV=4 AUTH/9 RPT=737
Authentication failed: Reason = Logon Failure
handle = 787, server = 10.150.12.213, user = tyler
Any idea what I'm doing wrong? I'm using almost all defaults.
ivillegas Wed, 01/30/2008 - 11:39
  • Silver, 250 points or more
Try to change the username and password and check again. Check if you have any access list configured on the concentrator.
