Output drops
Jan 24th, 2008
I have an Frame relay link point to point,and currently experimentes Output Drops.
Serial0/0/0:0 is up, line protocol is up
Hardware is GT96K Serial
Description: *** Data Link to AVON KASTRIN ***
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 21/255, rxload 9/255
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive set (10 sec)
CRC checking enabled
LMI enq sent 9912, LMI stat recvd 9912, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE segmentation inactive
FR SVC disabled, LAPF state down
Broadcast queue 0/64, broadcasts sent/dropped 12287/0, interface broadcasts 10635
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 1d03h
Input queue: 0/1000/0/0 (size/max/drops/flushes); Total output drops: 8523748
Queueing strategy: fifo
how can I eliminate this Output drops?
can anybody help me?
Roland
Roland,
That is a difficult one to answer (as well as complicated).
What types of traffic are you sending through the ptp? Are you sending VoIP? Do you have any QoS config on the router? If you do have QoS and you are prioritizing VoIP traffic properly then you are probably dropping data packets and not voice so it may be something you shouldn't have to worry about too much.
rpazosvargas Thu, 01/24/2008 - 12:30
Thank you bryan to take your time and answer me.
You are rigth, we use voice in other subinterface with Queueing strategy: weighted fair, but at the end is the same fiscal interface,
So is probably dropping data packets and not voice!
Thank you again
Rolando
Hieu Cao Thu, 01/24/2008 - 16:30
The only way for you to know that it's data being dropped instead of VoIP packets is to take a look at your QoS out.
Since you use VoIP, I would recommend that you use CBQWF with LLQ for your voice class instead of WFQ.
HTH,
Hieu
