Warning message
configuring terminal service 2621 for remote access use
Jan 24th, 2008
we currently have a 2621 in our network which we use to remote access various other devices. I have to add a new squid cable to add some other devices. I've been reading on async configurations and everything seems to be different than what we have configured..here is a partial of what we have
menu net text 1 L33 xxxrouter1
menu net command 1 telnet myport 2033
menu net text 2 L34 xxxxrouter2
menu net command 2 telnet myport 2034
menu net text 3 L35 xxxrouter3
menu net command 3 telnet myport 2035
menu clear text 1 Clear Line L33
xxxrouter1
menu clear command 1 clear line 33
menu clear text 2 Clear Line L34
xxxxrouter2
the config looks simple...if i just
plugged one of the connections from the rj45 squid cable into the aux port of a new device..what would i need to configure or command would issue on the 2621 to access the new device....(all new devices are up and running on our network-just have to get term server acccess to them)
There are no "ip host" configuration statments in the term server
Overall Rating: 5 (1 ratings)
Richard Burts Thu, 01/24/2008 - 18:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Richard
Good for you = an interesting question on something I have not thought about in a long time.
There are no "ip host" commands because those functions are provided in the menu system that is configured:
defines a command that is equivalent to ip host pointing to port 2033. (menu net text 1 defines the text that is displayed for command 1 and menu net command 1 defines the action that corresponds to that command).
So if you are going to add more cable connections you need to configure more menu choices (the text to display and the action to take)
Rick
Richard Burts Thu, 01/24/2008 - 19:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Richard
You are quite welcome.
Thanks for the rating.
Rick
