NAT on a Stick with IOS Firewall
Jan 24th, 2008
I have two Internet routers configured to allow vpn clients to connect and NAT back out for Internet access. On my 2801 with a fast ethernet outside interface it works fine. On my 2811 with an mlppp outside interface ip inspect stops http from working properly (pinging works fine). Both routers are running the same version of ios (12.4.12). Below is a snip of code from the router I'm having problems with.
ip inspect hashtable-size 8192
ip inspect name cbac_inspect ftp
ip inspect name cbac_inspect icmp
ip inspect name cbac_inspect esmtp
ip inspect name cbac_inspect udp
ip inspect name cbac_inspect http java-list 2 urlfilter
ip inspect name cbac_inspect tcp
interface Loopback1
ip address 172.20.202.17 255.255.255.252
ip nat inside
ip virtual-reassembly
interface Multilink1
ip address ###
ip nat outside
ip policy route-map vpn_in
crypto map vpnmap
ip local pool vpnpool 172.20.199.1 172.20.199.127
ip nat inside source list NAT-LIST interface Multilink1 overload
ip access-list extended NAT-LIST
permit ip 172.20.199.0 0.0.0.127 any
ip access-list extended vpn_in
access-list 2 permit any
route-map vpn_in permit 10
match ip address vpn_in
set ip next-hop 172.20.202.18
Disabling ip inspect on the outside (multilink1) interface fixes the problem. I would like to have ip inspect on the interface though so I can apply an inbound ACL. When I use the "sh ip nat trans" and "sh ip inspect all" commands I see the proper entries. When I do a packet capture I see a SYN, SYN ACK, ACK, HTTP GET *dead silence*. Any ideas?
aghaznavi Wed, 01/30/2008 - 13:20
  • Silver, 250 points or more
Please make sure here "dead silence " means the firewall allows the unwated traffic or anyother thing.
