4948 - layer 2 issue?
Jan 24th, 2008
Hi, I have 2 interfaces on a 4948 which are in VLAN 68, both connected to hosts. both interfaces are switchports, access vlan 68.
The hosts can't ping eachother through the switch.
Is there a restriction where you have to have a layer 3 int on the box that is working in order for it to pass layer2 traffic?
I'm not sure if this is a bug.
Our config looks good:
interface GigabitEthernet1/10
switchport access vlan 68
switchport mode access
interface GigabitEthernet1/29
speed 1000
duplex full
interface Vlan68
no ip address
shutdown
If I take the switch out of the picture, the hosts communicate. The switch cabling is good and both ports are up.
have any of you seen this?
snsjustin Thu, 01/24/2008 - 13:05
The VLAN being shutdown is more than likely the issue, can you do a "no shut" on it?
snsjustin Thu, 01/24/2008 - 13:10
Can the hosts ping their gateway? also if you do a "show ip interface brief" on the 4948 what is the status of the VLAN?
lgontarsk Thu, 01/24/2008 - 13:17
One of the devices is the gateway.
They can ping eachother only if the 4948 is out of the picture.
Show ip int brief does show it up...
Vlan68 8.7.70.13 YES manual up up
Edison Ortiz Thu, 01/24/2008 - 17:03
  • Hall of Fame,
    Founding Member
1) Go auto/auto on the end-hosts and the switchports. I see you hardcoded the speed/duplex on 1/29 - change it to auto.
2) Post the output from typing show mac-address-table
3) Assign an IP on SVI 68 that belongs on the same subnet as the end-hosts. Can you ping the end-hosts from the switch ?
4) Post the arp table from the end-hosts.
__
Edison.
