CISCO PIX 501 Problem
Jan 24th, 2008
I recently purchased a used PIX 501 only to find that it does not have the PDM software. It is running OS ver 6.1, but when typing in https:192.168.1.1 I can not get to the PDM but I am able to ping the IP address. ANy suggestions on where to get the PDM software and how to install it would be greatly appreciated.
guruprasadr Thu, 01/24/2008 - 20:16
  • Gold, 750 points or more
HI,
Ensure that you have a Cisco Connection Online (CCO) account. You need a CCO username and password to download PDM software. If you do not have a CCO account, go to http://tools.cisco.com/RPF/register/register.do and enter the information requested.
PLS RATE if HELPS.
Best Regards,
Guru Prasad R
robert.horrigan Mon, 01/28/2008 - 13:03
It may have PDM. Type /pdm ,also make sure that you allow https access in the cli to from your subnet
dongdongliu Mon, 01/28/2008 - 23:00
if you want to download PDM soft from cisco.com, be careful of PDM v1.1 is supported by PIX OS 6.1
