Question about ICND1&2 and CCNA test
Jan 24th, 2008
I want to get CCNA certified but I don't know which route to go. I heard you can take two separate tests or just one. I have taken Cisco Academy I, II, III and now taking Cisco IV, I also have AAS in LAN Management. Those that are CCNA certified or taken CCNA exam do you think it's better to take two park test or one test? Does anyone know how much it cost to take ICND1 and ICND2?
dbeare Fri, 01/25/2008 - 07:26
I think it mainly depends on how familiar you are with the materials. Personally, I went with the single test method, as it worked best for me, and I am glad that I did. If your background isn't in networking, many have suggested that taking the two tests separately is easier.
I believe the costs are $150 for the composite, or $125 separately for the tests. You will want to check http://www.pearsonvue.com to get the exact pricing information, as they are the ones who you set up the testing through. Best of luck.
