LMS 2.2 Netconfig from cmd line and mailing output .txt file ?
Answered Question
Jan 24th, 2008
The notes below I took on how to run netconfig jobs from the command line. What I would like to be able to do is email the output.txt file to my email address. Any ideas on how I could do this?
•Create a file that has all the devices the file is to be executed on. Example, /opt/CSCOpx/bin/devices.
•Create a file with the commands to be executed. Example, /opt/CSCOpx/bin/commands.
•chmod 666 /opt/CSCOpx/bin/devices.
•chmod 666 /opt/CSCOpx/bin/commands.
•from /opt/CSCOpx/bin run the command - ./cwconfig netconfig -u adminId -p adminPwd -createjob -mode enable -failure CONTINUE -devicefile /opt/CSCOpx/bin/devices -commandfile /opt/CSCOpx/bin/command
Correct Answer by Joe Clarke about 9 years 2 months ago
Parse the output of the cwconfig command. For example:
jobid=`cwconfig ... | grep jobId | cut -d'=' -f2`
Then, loop waiting for the job to complete. When it does, email the file:
cat /path/to/results.txt | sendmail [email protected]
Something like this should work:
running=1
while [ ${running} -eq 1 ]; do
status=`cwconfig netconfig -listjobs -u admin -p admin -status R | grep "JobId: ${jobid}"`
if [ -z "${status}" ]; then
results=`ls -1 /var/adm/CSCOpx/files/jobs/config/${jobid}/results.*.txt 2> /dev/null`
if [ -n "${results}" ]; then
cat ${results} | sendmail [email protected]
fi
running=0
fi
done
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 01/24/2008 - 16:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
getwithrob Thu, 01/24/2008 - 16:55
When I run a Netconfig job, the output is written to /var/adm/CSCOpx/files/jobs/config/jobid#. The only file of interest to me is the .txt file that gets put written to this same directory.
There are a ton of other files in that directory if a ton of devices are selected. I'd rather not email these files....
Correct Answer
Joe Clarke Thu, 01/24/2008 - 18:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
running=1
fi
running=0
fi
done
getwithrob Fri, 01/25/2008 - 03:59
You rock Joe!!!
I'll give it a try in awhile....
Thanks man-
