Backup ISDN line comes up When Primary Frame has not failed.
Jan 24th, 2008
I have a cisco 2800 router with Frame-Relay Primary and ISDN a backup. The problem we're haveing is the ISDN backup circuit is coming up even though the Primary Circuit has not failed. Can you please take a quick look at the config below and let me know what you think
interface Loopback0
ip address 172.17.65.137 255.255.255.252
interface FastEthernet0/0
ip address 172.17.88.1 255.255.255.128
no ip redirects
no ip proxy-arp
no ip mroute-cache
duplex full
speed 100
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
no ip redirects
no ip proxy-arp
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
no fair-queue
service-module t1 timeslots 1-6
cdp enable
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
bandwidth 384
ip address 172.17.123.130 255.255.255.128
no ip redirects
no ip proxy-arp
no ip mroute-cache
frame-relay interface-dlci 223
class 360
interface BRI0/1/0
ip address 172.17.212.123 255.255.255.128
no ip redirects
no ip proxy-arp
encapsulation ppp
dialer idle-timeout 60
dialer map ip 172.17.212.1 name 211-ISDN/FAIR broadcast 1028819094847471
dialer map ip 172.17.212.1 name 211-ISDN/FAIR broadcast 19xx4xx7471
dialer load-threshold 2 either
dialer-group 1
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 x166439684x1x1
isdn spid2 x166439687x1x1
no cdp enable
ppp authentication chap
ppp multilink
router eigrp 1
network 172.17.0.0
no auto-summary
no eigrp log-neighbor-changes
ip route 0.0.0.0 0.0.0.0 172.17.212.1 200
ip route 172.17.212.1 255.255.255.255 BRI0/1/0
ip http server
ip http authentication local
ip http secure-server
ip tacacs source-interface FastEthernet0/0
ip access-list extended Sacramento_ACL
permit ip host 172.17.65.137 host 172.17.65.125
permit ip 172.17.88.0 0.0.0.255 any
But when the primary Frame-relay link is still active, the ISDN link comes up. See log messeges from the router below:
Jan 23 12:58:51.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:1, changed
state to up
Jan 23 12:58:59.420: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to up
Jan 23 12:58:59.420: %ISDN-6-CONNECT: Interface BRI0/1/0:2 is now connected to 19094847471
N/A
Jan 23 12:59:00.759: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:2, changed
state to up
Jan 23 13:00:14.173: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from 19094847471
211-ISDN/FAIR, call lasted 83 seconds
Jan 23 13:00:14.413: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jan 23 13:00:15.117: %ISDN-6-DISCONNECT: Interface BRI0/1/0:2 disconnected from 19094847471
211-ISDN/FAIR, call lasted 75 seconds
Jan 23 13:00:15.361: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to down
Jan 23 13:00:15.413: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:1, changed state to down
Jan 23 13:00:16.361: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:2, changed state to down
Jan 23 14:28:14.177: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jan 23 14:28:14.177: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 19094847471
N/A
Jan 23 14:28:15.516: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:1, changed
state to up
Jan 23 14:28:23.446: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to up
Jan 23 14:28:23.446: %ISDN-6-CONNECT: Interface BRI0/1/0:2 is now connected to 19094847471
N/A
Jan 23 14:28:24.782: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/1/0:2, changed
state to up
Jan 23 14:29:36.847: %ISDN-6-DISCONNECT: Interface BRI0/1/0:2 disconnected from 19094847471
123-2811-1#
Richard Burts Thu, 01/24/2008 - 18:00
Larry
There are some things that would be helpful that you have deleted in the config that you posted. In particular the BRI has dialer-group 1 but you have not given us dialer-list 1. So we do not know what is interesting traffic that could bring up the ISDN interface.
Given the time interval indicated in the logs that you posted I discount the possibility that EIGRP traffic over the ISDN or CDP traffic over the ISDN may be the cause. But it would be good to know what is "interesting" on this side.
My other thought is that the log messages that you have posted do not clarify whether this router is initiating the calls or is activating when it receives calls. If you run debug dialer through several cycles of activation and post the output it should help clarify this aspect. It might also be helpful if you would run debug ppp negotiation and post that output.
Rick
lacox3131 Mon, 01/28/2008 - 07:42
Rick,
Here is the dialer-list 1;
access-list 177 deny eigrp any any
access-list 177 deny ip any 224.0.0.0 0.255.255.255
access-list 177 deny ip any host 255.255.255.255
access-list 177 permit ip any any
dialer-list 1 protocol ip list 177
Richard Burts Mon, 01/28/2008 - 08:55
Larry
Thank you for posting the dialer list information that I asked about. It does clarify that EIGRP (as well as 224.x.x.x multicast) is not interesting. Perhaps run debug dialer and post the output when it has run through a couple of cycles of the ISDN interface going active.
Rick
