Switch port wih multi-vlan for voice and data?? Help....
Jan 24th, 2008
Hi guys,
I've a situation where my VOIP and DATA on a different segments. Voice is 10.x.x.x riding on VLAN 701. And my data is 192.x.x.x riding on VLAN 100.
The problem occur when our receptionist PC have a software installed for call forwarding for our general line. This software need to be on the same vlan with the IP Phone vlan which is 701. If I put her PC on those vlan, she can't access
to our LAN which is vlan 100. So she can't check her email etc.
Can I know what is the options I have? Can I configured multi-vlan for her PC on the switch? We are using Cisco PoE 3560 switch. Thanks.
Brandon Buffin Mon, 01/28/2008 - 07:24
You will need to enable inter-VLAN routing either using an external router or layer 3 switch or one of your 3560 switches. The following link shows an example of inter-VLAN routing for 3750/3560/3550 switches.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Also, see the following link for other inter-VLAN routing configuration examples.
http://www.cisco.com/en/US/tech/tk389/tk815/tk857/tsd_technology_support_sub-protocol_home.html
Hope this helps. If so, please rate the post.
Brandon
