01-24-2008 06:51 PM - edited 03-05-2019 08:41 PM
Hi - in an extended TCP ACL - is there a way to permit or deny a range of port numbers in a single line? I know the port operators (gt, lt, eq, neq) - but they don't seem to accomplish this? Also - can someone recommend a good link for further info? Any help is greatly appreciated.
Jim Woodward
Solved! Go to Solution.
01-24-2008 07:00 PM
Jim
Yes there is a way to permit or deny a range of ports. There is now a range option in the configuration of extended access lists. Here is an example from one of our operational access lists which uses the range option:
access-list 121 deny tcp any range 0 65535 any range 0 65535 log-input
This particular example is used in part of our
RFP check and specifies a very wide range. Most of the time you would want a more narrow range.
You can configure a range on the source port, on the destination port, or on both (as this example does).
It works well.
Rick
01-24-2008 07:00 PM
Jim
It works well.
Rick
01-24-2008 07:55 PM
Thank you very much!!
Jim
01-24-2008 08:07 PM
Jim
I am glad that my answer was helpful in resolving your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which did resolve the question.
The forum is an excellent place to learn more about Cisco networking. I encourage you to continue your participation in the forum.
Rick
