SSH enable on cisco 3560 switch
Jan 24th, 2008
I followed below steps to enable SSH in cisco 3560 switch
Step 1
configure terminal
Step 2
hostname hostname
Step 3
ip domain-name domain_name
Step 4
crypto key generate rsa
After configuration when i ssh on switch it ask for username/password
login as: cisco
[email protected]'s password:
Pls suggest how to enable ssh & how to create username/password for ssh on 3560 switch
shrikar.dange Fri, 01/25/2008 - 00:16
hi,
as ankur said u need to configure username and password for the switch.
Also issue aaa new-model command then configure username and password otherwise ssh will not get enabled.
To aplly to the telnet sessions use following:
switch(config)#line vty 0 15
switch(config-line)#transport input ssh
HTH,
regards,
shri :)
glen.grant Fri, 01/25/2008 - 14:59
If you are not using any kind of AAA authentication (tacacs) then you would need a username and password . If you are using AAA then you can set to use AAA and if thats not there it falls back to the line and enable secret passwords.
