PSTN Dialing
Jan 25th, 2008
Sir,
I am working on voip setup. My topology you can see below:
User-------PBX1------R1----------------------R2-----PBX2---------PSTN
PBXs are connected with Routers and PSTN via E1 Pri whereas Routers R1 and
R2 are connect with each other through E1 link. Lets suppose site-1 has site
code 1000 and site-2 has code 2000 so when user dial 2000 and extension, it
connect to user of site-2. In old topology without voip, when user dial
2000, then 00 and then pstn number, it able to call users on pstn. Old
topology is :
User-------PBX1---------------------------------PBX2---------PSTN
But now through voip setup, can i do the same thing ? I think it should be
possible with configuration sample below:
R1
dial-peer voice 200000 voip
destination-patern 200000
session target ipv4:1.1.1.2
R2
dial-peer voice 200000 pots
port 1/0:15
forward-digit 2
I think using above configuration R2 will send 00 to PBX2 and an end-to-end
connection will be establish between user of site-1 and PBX2 and after that
user can dial whatever pstn number he wants. IF this will not work then i
have to configure a number of dial-peers for pstn like 7 digits, 8 digits
and with destination-patern "T" etc.
Please help me out regarding this issue. Am i thing in good way otherwise
purpose me solution Waiting........
Best Regards
Rameez
Paolo Bevilacqua Fri, 01/25/2008 - 02:51
router will give to pbx all digits after the matched destination-pattern.
So if;
destination-pattern 2222T
And you call 2222001408256400
R2 will pass 001408256400 to PBX2
rameezsardar Fri, 01/25/2008 - 20:08
Thanks for reply. What if i create a dialpeer:
R1
Dial-peer voice 222200 voip
detination-patern 222200
session target ipv4: R2-IP
R2
dial-peer voice 222200 pots
destination-patern 222200
foward-digit 2
port 1/0:15
what u think using this above configuration, is it not possible? I believe as user press 222200 routet R1 will match dial-peer and forward to R2. R2 will match dialpeer and send just 00 to PBX2. As PBX2 recieve 00 it will seize pstn trunk so because of just pressing 222200 a trunk will be establish from user and pbx2 and as user press remaining digits, that will simply pass to pstn over voip. I think not need to add "T" in destination-patern. If i am wrong please correct me.
best regards
Paolo Bevilacqua Sat, 01/26/2008 - 02:39
this will work if PBX2 has analog lines to PSTN.
It would cause two stage dialing with second dial-tone from pstn.
But, if PBX2 has ISDN to PSTN, it will not work, because PBX2 will send a call setup with no called number to PSTN, and this generally causes an error.
I still do not understand why you think that a regular setup with T will not work, it should,
rameezsardar Sat, 01/26/2008 - 12:35
Friend,
i did not say that "T" is not work. But with T users have to wait for interdigit timeout or press # that is not acceptible to them thats why i dont go for it. Ok tell me how we can tweak this timeout so that user dont feel and delay after dialing pstn number of any length.
Secondly, i tested the same type of configuration with pri and it worked. For example:
phone1---pbx1---router1------router2----pbx2---phone2
pbxs are connected with router with e1 pri and routers are connected with each other via e1 link. Site1 code is 1000 and site2 code is 2000
site1 config
dialpeer 2000 voip
destinationpatern 2000
session target router2 ip
site2 config
dialpeer 2000 pots
destination 2000
port 1/0:15
forward digit all
so user dial 2000 and extention of any length, it worked properly and no error as you said. I would tell you one thing, in real i am adding "signaling forward rawmsg" in all voip DPs and "supplementary-service pass-through" in pots DPs.
Waiting.....
Paolo Bevilacqua Sat, 01/26/2008 - 14:14
I would like to see the q831 trace for the config you mentioned. To see if it is sending the digits in band or with info message.
Anyway, as you know the interdigit delay, when set to 3, is not much of a problem.
The alternative is that you build a dialplan that matches all or most numbers length .
usually that is not very difficult especially if it is about one single city. Get a phonebook and you will be able to rebuild the numbering tree, even if you country has variable-length numbering, it can be done .
rameezsardar Tue, 01/29/2008 - 06:49
Dear p.bevilacqua ,
Thanks for reply. you can find debug isdn q931 output in attachment.
Routers Configurations:
Router A
dial-peer voice 99 pots
destination-pattern 99..
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 8701 voip
destination-pattern 8701
session target ipv4:10.0.0.2
Router B
dial-peer voice 99 voip
session target ipv4:10.0.0.1
dial-peer voice 8701 pots
direct-inward-dial
port 1/0:15
forward-digits 0
Note: In dialpeer 99 you see i define 99.. where .. is because i have an other dialpeer with destination-patern 9900 thats why so don't confuse it. See i just define 99.. and actual number dialed is 9935240 and call is made properly no issue at all.
Waiting for your immediate response.
Best Regards
Paolo Bevilacqua Tue, 01/29/2008 - 07:51
yes in the trace you sent the router is doing proper overlap dialing. If you manage to reproduce this when calling to PSTN, there should be no delay, once you have passed enough digits to PSTN you should receive connect and the call goes through.
