Show Service-Module and Show Controllers T1
Answered Question
Jan 25th, 2008
I just like to know what is The difference on the router commands "Show Service-Module and Show Controllers T1" and when should we use those 2 commands. Why does Some routers have Show Service-Module command but no Show Controllers T1 or either the other way around. Thanks you so much...
Correct Answer by Edison Ortiz about 9 years 6 months ago
show controllers T1 will display the information about the T1 serial card in the router.
show service-module will display the information about an internal CSU/DSU.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Sat, 01/26/2008 - 19:55
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
