ACE: FT Contexts' Names
Answered Question
Jan 25th, 2008
Do a pair of FT Contexts have to have the exact same names?
thanks.
Correct Answer by Gilles Dufour about 9 years 6 months ago
Why don't you use automatic config synch ??
With config synch the name will obviously be the same.
So, if you do manual synch currently, and use different name (could be possible I think), you will never be able to implement auto synch.
Therefore, I don't see why you would want to do this.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Fri, 01/25/2008 - 02:29
  • Cisco Employee,
Gilles.
danger_mousie Fri, 01/25/2008 - 02:41
It was purely for convenience. I don't actually need to do it. I wanted to specify in the context name whether is was Active or Standdby by design. I'll be using autosynch once all physical connections are up.
Thanks again :)
