From CatOS to IOS
Answered Question
Jan 25th, 2008
We have a Cat 4503 which has a supervisor card which is now EoL and running CatOS. We are thinking of replacing the card with a Sup II+ which is Cisco IOS.
What will this entail? Is there documentation to support this?
The Cat 4503 has a 64M DRAM, 6.1(5) ROMMON, 16M Flash and 2 power supplies.
Will this be okay to do a direct swap to a Sup 2+ without any hardware upgrade?
Please help.
Correct Answer by ankbhasi about 8 years 12 months ago
Hi Friend,
As you mentioned you have 4503 with 64 MB DRAM but this statement is bit wrong because 450 is a chassis and it does not have any memory in itself.
It is sup which is having DRAM and FLASH. So as you mentioned you are upgrading to SUP2+ it is very well supported in 4503 chassis and you can simpl insert the sup in the chassis.
http://www.cisco.com/en/US/products/hw/switches/ps4324/ps4332/index.html
Now when you insert the line card we have to see if the image running on your sup which is sup2+ supports the line card that you have or not.
ANkur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 01/25/2008 - 03:16
Hi Friend,
ANkur
