ACE: conn-limit by source?
danger_mousie
Is it possible to limit the number of concurrent connections to a set number per source IP?
You can have the same rserver in different serverfarm. That's no problem.
Only drawback is that the same probes will be run for each serverfarm.
Gilles.
Gilles Dufour
no.
Unless you know the ip address you want to limit.
In this case, you can match that traffic with a class-map and use a separate serverfarm for each ip where you can specify a conn-limit.
Gilles.
As they are the same servers, wouldn't this mean having the same servers in different serverfarms? I believe this is not recommended, is this the case?
Gilles.
