Pix 515e cannot boot up!!!
Jan 25th, 2008
I face the problem when i boot up the PIX 515e firewall, belows are the message which appear at my console hyperterminal.
Watchdog timeout failure! Please contact customer support.
PC SP STATE Runtime SBASE Stack Process
Hrd 001ecf11 00950334 00565bc0 10 0094f3ac 3812/4096 arp_timer
Lrd 00103710 009f35a4 005660a0 0 009f25b4 4080/4096 FragDBGC
Lrd 00103710 009ff85c 005660a0 0 009fe86c 4080/4096 dbgtrace
Lrd 00103710 00a0190c 005660a0 0 009ff91c 8176/8192 Logger
Hwe 003f6998 00a0495c 0055e7c0 0 00a029e4 8024/8192 tcp_fast
Hwe 003f6911 00a06a0c 0055e7c0 0 00a04a94 8024/8192 tcp_slow
Lrd 00103710 00b3d1f4 005660a0 0 00b3c204 4080/4096 xlate clean
Lrd 00103710 00b3e2a4 005660a0 0 00b3d2b4 4080/4096 uxlate clean
Mrd 00103710 00cd6684 00565c10 0 00cd4694 8176/8192 tcp_intercept_timer
_process
Lrd 00103710 00d82f6c 005660a0 0 00d81f7c 4080/4096 route_process
Hrd 002f45ac 00d83f94 00565bc0 50 00d8302c 3752/4096 PIX Garbage Collect
or
Hwe 0021a459 00d8e4c4 00565bd8 20 00d8a55c 15992/16384 isakmp_time_keepe
r
Lrd 00103710 00da8d04 005660a0 0 00da7d14 4080/4096 perfmon
Mrd 00103710 00dd3144 00565c10 0 00dd1154 8176/8192 IPsec timer handler
Hrd 003a8933 00de7b54 00565bc0 30 00de5c0c 7684/8192 qos_metric_daemon
Mrd 00103710 00e02714 00565c10 0 00dfe724 16368/16384 IP Background
Lrd 00103710 00eb5154 005660a0 0 00eb4164 4080/4096 pix/trace
Lrd 00103710 00eb6204 005660a0 0 00eb5214 4080/4096 pix/tconsole
Thank you
-Gilbert
jojuarez Mon, 01/28/2008 - 15:59
Hi Gilbert,
That error is usually related to issues w/ memory. You can try to upload the image again to the PIX. If the issue continues after having done that, replacement is needed.
