ACS SE Private Key Backup
Answered Question
Jan 25th, 2008
How do I backup the private key in ACS SE. I already have the public key certified by a comercial CA and don't want to waste money spent in buying the certificate. Reason I want to backup because I am getting following error on the console and the services have stopped.
"API called before initialised at H:\ismg_israel_acs\Acs\EndPoint\Core\endpoint.c
pp:394".
Cisco Secure ACS: 4.1.4.13
Appliance Management Software: 4.1.4.13
Appliance Base Image: 4.1.1.4
CSA build 4.0.1.543.2: (Patch: 4_0_1_543)
CSAdmin -- stopped
CSAuth -- stopped
CSDbSync -- stopped
CSLog -- stopping
CSMon -- starting
CSRadius -- starting
CSTacacs -- stopped
Can I use the backup feature? Will it also backup the private key?
Correct Answer by Jagdeep Gambhir about 9 years 3 months ago
Manoj,
Unfortunately, there is no way to really export just the private key and certificate,
which can be reimported into the ACS. There has been a feature request regarding this
feature, in order to allow the export of private keys and certificates for backup purposes. The Bug ID is: CSCed14965.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCed14965
However, what you can do is perform a backup of the database. This will save the registry
that includes the certificate and the private key. Then you can restore this backup file
on a new machine and choose to restore the System Configuration part. This will restore
the certificate and private key into the ACS Certificate page.
Hope that helps
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Fri, 01/25/2008 - 05:51
  • Red, 2250 points or more
Manoj,
Hope that helps
~JG
