ASK about SSL VPN Client ASA 5540
Jan 25th, 2008
I have configurated the SSL VPN Client Tunneling, and I can to connect with the ASA in a properly way, and the IP pool created by that asign a correct Ip of my intranet LAN network but I can't do contact with the LAN network, for example ,send a ping a some hots of the LAN and don't answer ,Somebody Know if I must config a ACL or NAT in some interface????
or what can I do??
I hope somebody can answer me..
Thanks.
Ignacio Calvo
owillins Thu, 01/31/2008 - 07:29
Make sure you confiugred proper ACL and proper subnet range in your device.
pszczola1 Thu, 01/31/2008 - 12:55
Make sure that your IP pool for VPN connections is not translated
example:
let say you have local pool 10.0.2.32 - 10.0.2.63
access-list nonat extended permit ip any 10.0.2.32 255.255.255.224
or
access-list nonat extended permit ip (LAN subnet ) 10.0.2.32 255.255.255.224
nat (inside) 0 access-list nonat
