BGP Exam CCIP
Jan 25th, 2008
Hi Guys,
I am planning to give BGP CCIP exam and need any tips from recent takers specially on simulations. How many simulations usually come in the exam and how much time should you target to finish single simulation.
Thanks for your time and tips.
tperrier Wed, 01/30/2008 - 01:32
I'm not a recent taker (late 2005), but I doubt the exam changed much format wise. And the format was the same as all other CCxP level exams I did, so count on a couple or maybe three sims if you're lucky. How much time to do them? The time it takes you to do them right, but less than half an hour. ;) These sims are never really complicated, if you're having difficulty with one, better to skip it and concentrate on the rest of the exam, rather than spending precious minutes trying to make it work (time flies fast when at the console, without one always realizing it).
