Changing subscribers call transfer settings - Unity 4.2.1
Answered Question
Jan 25th, 2008
I need to change the Transfer type for existing users and can not find the option to do this in Bulk Edit, have already update the subscriber template for users going forward..is this option available to me without having to do it on a user by user basis or getting them to update in Ciscopca? Thanks.
Correct Answer by ranpierce about 9 years 6 months ago
It is the "Transfer" tab
you might have to play around with it
rlp
Overall Rating: 5 (1 ratings)
ranpierce Fri, 01/25/2008 - 07:16
  • Silver, 250 points or more
What version of Unity, it should be in Bulk Edit. I am checking again. I have 4.2.1
rlp
maratimer_2 Fri, 01/25/2008 - 07:19
Unity 4.2.1 - the tool is the version that came with the install. perhaps I need to download a new version. LEt me know if you find it, I may just need that extra set of eyes. Thanks for responding.
Correct Answer
ranpierce Fri, 01/25/2008 - 07:20
rlp
maratimer_2 Fri, 01/25/2008 - 07:28
I've been staring at that all morning :>)...its cryptic but makes sense once you look at the HELP file (famous last words).
Enable Transfer. Select “true” to enable transfers for all selected subscribers and “false” to disable it. If you disable transfer here, Unity will not try to ring the subscriber's phone when a user dials their extension from the opening greeting for instance. If you enable transfer and the subscriber doesn't have a custom transfer string set on the “Call Transfer” page in the SA, their extensions number will be used (i.e. the value on the Profile page will be dialed directly).
