banner login - how many char's can it be?
Jan 25th, 2008
I've noticed that different revs have different lengths. I looked all over Cisco's website and the only thing I can find is the sending a message length from a session. or maybe I'm just using the wrong keywords. any links or helps would be appreciated.
Overall Rating: 4.5 (2 ratings)
Collin Clark Fri, 01/25/2008 - 08:42
I have not heard of a limit. In the old days, before security was important, people would do ASCII art with their logins:-) That took a lot of lines and characters so I would think it's pretty big. How large is your banner?
encadmin1 Fri, 01/25/2008 - 13:02
It was about 400 char's.. I shorted it to about 260 and it fit on my 2960G, but not in my 2950... the 60's running 12.2 and the 50's running 12.1. Maybe its my terminal software i'm using? Hmmm.....
Collin Clark Fri, 01/25/2008 - 13:08
If there is nothing confidential, post it and I'll try it on a lab box.
Collin Clark Fri, 01/25/2008 - 13:37
Nice Arul! Be careful not to post links that require Partner access since most people on here don't have that access ;-)
encadmin1 Fri, 01/25/2008 - 13:56
K. I got it to work. what I did was put the message in word and used the enter key about every 100 char's so that it had return character's in it. I copied all the lines with the return char's and it all went in. I think it's a formatting issue.
so resolved. And ty for all the good replies ^^
