Radius Issue
Answered Question
Jan 25th, 2008
i have a user that is only able to use the wireless connection while connected to the LAN. When the user disconnects i am able to see the client assoc but cannot communicated. Any ideas.
Correct Answer by manjesin about 9 years 1 month ago
Here are few thing which you can check :-
* When it show associated .. do ipconfig on computer ... check if there any ipaddress or not .. if it is not getting ip address .. communication will not take place....
* Assign static ip address for testing .
* If we have the correct ip address ..
Do clear arp on AP once or reboot ..
Then, try to connect again ..
Thanks ..
Pls rate .. it solution works for you so that other can benefit of these steps
Overall Rating: 5 (1 ratings)
Correct Answer
manjesin Sat, 01/26/2008 - 13:23
Thanks ..
tpacjer Sat, 01/26/2008 - 13:37
right direction dhcp scope was distributing worng gateway after scope corrected issue was resolved
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
