Best practice for placement of Root Guard ?
Answered Question
Jan 25th, 2008
If I use the following basic design, where is the best place for configuring root guard ?
Two 6500's at the core, one is the root and the other secondary. Hanging off each 6500 I have say 3 x 3550 switches.
Am I right in thinking that the best blace to configure root guard is on the access switches (3550's), since only the rouge switch will be blocked from joining the network ?
If I were to configure this on the root switch as I have been reading I would surely risk one or both of my core switches completely 'blocking' and layer 2 wise would grind to a halt until the offending switch was located and removed ?
Cheers,
Phil.
Correct Answer by Nagendra Kumar ... about 9 years 3 months ago
Hi Phil,
Yes. It is recommended to configure root guard on all appropriate interface of the designated switch.
Nagendra
Overall Rating: 5 (1 ratings)
Correct Answer
Nagendra Kumar ... Fri, 01/25/2008 - 08:32
  • Cisco Employee,
Hi Phil,
Nagendra
