ACS certificate
Answered Question
Jan 25th, 2008
I used the ACS SE 4.1 to generate a certificate to be used for PEAP authentication.when I generate the Certificate "Generate Self-Signed Certificate", it has a validity of one Year.
How can I specify the validity to 3 years or more.?
thanks
Correct Answer by manojsaxena about 9 years 3 weeks ago
Self Signed Certificates have a default period of 1 year and can not be changed. There are various links on Cisco.com stating it one of them is as under.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a0080545a29.shtml
Manoj
Rate useful posts.
Overall Rating: 5 (1 ratings)
somebody314 Wed, 01/30/2008 - 02:43
The default period is 1 year for self-signed certificates which AFAIK cannot be modified.
raboud888 Wed, 01/30/2008 - 13:13
The Cisco ACS server defaults to a 1 year certificate that can not be changed.
However, you can, and what I have done is use OpenSSL to generate x509v3 certificates that have a validity of 3 years then import the certificates into the ACS.
