MPLS supported by 3845 router?
Jan 25th, 2008
Hello all,
Does the 3845 router supports all the managment for MPLS and the protocols ISIS & BPG? What about the interfaces STM-1, could they be used for MPLS?
I'm planning to use this routers in a Core backbone, not only in a large enterprise network. Do you think it could be done with this router?!
Thanks in advanced for your help, I really appreciate that.
Best Regards,
Ivan
amritpatek Thu, 01/31/2008 - 11:36
The Cisco 3845 Integrated Services Router does supports all management for MPLS and other protocols like ISIS and BGP. This router can be used for heavy to medium traffic load on Core but for high traffic load you should use a higher end router.
