ACS static IP
I am setting up a new ACS appliance (Cisco 1113). I followed the steps to setup a static ip address but when I do a show, it still says yes to dhcp enabled. I am on a working network, the ACS got a dhcp address. The system says new ip address set, but it does not. Any ideas? Here is what I have done.
asc1> set ip
Use Static IP Address [Yes]: Y
IP Address [10.36.254.222]: 10.36.254.222
Subnet Mask [255.255.255.0]: 255.255.255.0
Default Gateway [10.36.254.1]: 10.36.254.1
DNS Servers (Separate multiple servers with a space) [10.14.100.13]: 10.36.254.2
00 10.14.100.13
New Configuration:
DHCP: No
IP Address: 10.36.254.222
Subnet Mask: 255.255.255.0
Default Gateway: 10.36.254.1
DNS Servers: 10.36.254.200 10.14.100.13
IP Address is reconfigured.
Confirm the changes? [Yes]: Y
New ip address is set.
Default gateway is set to 10.36.254.1.
DNS servers are set to 10.36.254.200 10.14.100.13.
Test network connectivity [Yes]: Y
Enter hostname or IP address: 10.8.0.24
Pinging 10.8.0.24 with 32 bytes of data:
Reply from 10.8.0.24: bytes=32 time<10ms TTL=125
Ping statistics for 10.8.0.24:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Test network connectivity [Yes]: N
Stopping all ACS Services
Stopping service: CSAdmin.
Stopping service: CSAuth..
Stopping service: CSDbSync.
Stopping service: CSLog.
Stopping service: CSMon.
Stopping service: CSRadius..
Stopping service: CSTacacs..
Starting all ACS Services
Starting service: CSAdmin...
Starting service: CSAuth.
Starting service: CSDbSync.
Starting service: CSLog..
Starting service: CSMon.
Starting service: CSRadius.
Starting service: CSTacacs..
asc1>Show
asc1.ridemetro.org
Cisco Secure ACS: 4.1.1.23
Appliance Management Software: 4.1.1.23
Appliance Base Image: 4.1.1.4
CSA build 4.0.1.543.2: (Patch: 4_0_1_543)
Session Timeout: 10
Last Reboot Time: Fri Jan 25 10:49:31 2008
Current Date & Time: 1/25/2008 11:29:39
Time Zone: (GMT-06:00) Central Time (US & Canada)
NTP Server(s): 10.100.101.13
CPU Load Free Disk Free Physical Memory
0.00% 17.0 GB 787 MB
Appliance IP Configuration
DHCP Enabled. . . . . . . . . . .: Yes
IP Address. . . . . . . . . . . .: 10.36.254.222
Subnet Mask . . . . . . . . . . .: 255.255.255.0
Default Gateway . . . . . . . . .: 10.36.254.1
DNS Servers . . . . . . . . . . .: 10.14.100.13
--- Please hit enter to continue ---
CSAdmin running
CSAuth running
CSDbSync running
CSLog running
CSMon running
CSRadius running
CSTacacs running
CSAgent running
asc1>
David
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Fri, 01/25/2008 - 10:41
  • Red, 2250 points or more
David,
For setting up IP address we need to make sure that ACS SE is connected to a working Ethernet connection before setting or changing the IP address of your ACS SE.
If the port is down or not connected then appliance will not display any ip address, even if it was already configured
If still issue is there try to set up bottom port.
Note To set or change the IP address of your ACS SE, ACS SE must be connected to a working Ethernet connection.
~JG
Do rate helpful posts
ismail884 Thu, 01/31/2008 - 07:06
try to enable dhcp on the interface,and when you got the IP address from DHCP.try to reconfigure it using static IP address.
valstan Thu, 01/31/2008 - 08:25
Hi David,
I can't be a big help in your case(we run the same version, but on WIN box), but I noticed there are a maintenance update 4.1.4 SE. Also it seems the DHCP IP address is the same as the static one, isn't it?
Yes I tried so many things to get it to work. In the example I included in this thread I did try to use the dhcp address as the static.
I opened a TAC case. The engineer had me downlod a new version of the recovery cd. It did not resolve the problem either. He ended up sending me a new ACS SE RMA. That one works fine. Thanks for all the comments.
mkress Tue, 02/12/2008 - 01:06
Hello David,
we have the same issue. We have to 1113 with ACS 4.1.1.23 and the system changes the manually configured ip to dhcp. Was it really a hardware problem on your appliance?
Please, give me a short answer.
Thank you,
Markus
fargier Wed, 02/13/2008 - 01:56
I have exactly the same issue with the same HW and same OS 4.1.1.23. All of you change the HW?
I have two ACS with this HW. The HW is new, first time that I see that with ACS. And the issue is on both appliance.
Is it working if you use DHCP?
I see that it's working with Static only if i enter an IP like 192.168.001.001 - There is no connectivity if I use 192.168.1.1
But if I reboot the appliance, it still try DHCP.
Very strange.
mkress Wed, 02/13/2008 - 04:18
I opened a case and the engineer told me to start a RMA. So I think it's really a hardware issue. I've no more information about that strange behavior.
Ciao,
Markus
fargier Mon, 02/25/2008 - 03:32
Is it ok for you with news appliances?
Cisco sent me other appliances but i still have this issue. I impossible to have Static IP working properly! DHCP is always enable!...
Thanks for your answer.. And i you have some ideas..
DWAM_2 Wed, 03/19/2008 - 09:46
Thank you for this conversation.
I've got the same behaviour on two ACS :(
I'm not happy ! I think I will have to open a case and do RMA....
Here is the same output :
radiusnord> set ip
IP Address [172.25.16.11]:
Subnet Mask [255.255.248.0]:
Default Gateway []: 172.25.16.1
DNS Servers (Separate multiple servers with a space) []: 172.25.16.10 10.200.1.1
New Configuration:
DHCP: No
IP Address: 172.25.16.11
Subnet Mask: 255.255.248.0
Default Gateway: 172.25.16.1
DNS Servers: 172.25.16.10 10.200.1.10
Confirm the changes? [Yes]: Yes
Default gateway is set to 172.25.16.1.
DNS servers are set to 172.25.16.10 10.200.1.10.
Stopping service: CSAuth...
Stopping service: CSRadius...
radiusnord> Show
radiusnord.chu-amiens.local
Session Timeout: 10
Last Reboot Time: Thu Mar 20 01:33:42 2008
Current Date & Time: 3/20/2008 02:01:07
Time Zone: (GMT+01:00) Brussels, Copenhagen, Madrid, Paris
NTP Server(s): 172.25.82.8
0.00% 16.5 GB 787 MB
IP Address. . . . . . . . . . . .: 172.25.16.11
Subnet Mask . . . . . . . . . . .: 255.255.248.0
