Warning message
CCM 5.1.3 Attendant Console Extra ? **LASTNAME** **PRIMARYEXTENSION**
Rob Huffman Fri, 01/25/2008 - 09:56
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jackie,
Can you check to see if you had perhaps used BAT to insert 6 Users previously. There is a really odd 5.1 Bug that actually puts this info into the Directory;
You may be hitting this very odd Bug;
CSCsh53133 Bug Details
BAT overwrites last names with **LASTNAME**
Symptom:
When using Bulk Administration / Users / Update User function, BAT overwrites last names with **LASTNAME**
Conditions:
The BAT file looks as follows:
USER ID,PASSWORD,MANAGER USER ID,DEPARTMENT,PIN,DEFAULT PROFILE,USER LOCALE,TELEPHONE NUMBER,PRIMARY EXTENSION,ASSOCIATED PC,IPCC EXTENSION,MAIL ID,USER GROUP 1,CONTROLLED PROFILE 1,CONTROLLED DEVICE 1
userid,,,test,,,,,,,,,,Standard CCM End Users,SEPXXXXXXXXXXXX
Workaround:
1. Modify BAT file so it includes 'LAST NAME' field set to '*'. This field should be before the user group, user profile and controlled device fields.
Example:
USER ID,LAST NAME,PASSWORD,MANAGER USER ID,DEPARTMENT,PIN,DEFAULT PROFILE,USER LOCALE,TELEPHONE NUMBER,PRIMARY EXTENSION,ASSOCIATED PC,IPCC EXTENSION,MAIL ID,USER GROUP 1,CONTROLLED PROFILE 1,CONTROLLED DEVICE 1
userid,*,,,test,,,,,,,,,,Standard CCM End Users,SEPXXXXXXXXXXXX
2. When using above BAT file, specify '*' in the 'Value for fields to be ignored' field on the BAT job configuration page.
1st Found-In
5.1(1.1000.3)
Fixed-In
5.1(1.2105.1)
5.1(1.9131.22)
5.1(1.9131.23)
5.1(2.1000.11)
6.0(0.9901.136)
6.0(1.1000.37)
6.1(0.39000.15)
6.1(0.39000.16)
Hope this helps!
Rob
