Problem when connecting PBX to Gateway
Jan 25th, 2008
hello,
you find the scheme in the below image.
the problem is when that the phone behind the PBX (site A) cannot call phone behind PBX (site C), and when i debug isdn q931, the message : " service opertional violated " is displayed in the gateway near to site B.On the contrary, the call from phone behind PBX (site C) to phone (site A) works succefully.
Help me please.
thanks at advance
Overall Rating: 5 (1 ratings)
dbenattou Fri, 01/25/2008 - 13:57
this is the debug :
Router-SiteB#
*Jan 25 16:05:21.645: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 910945
*Jan 25 16:05:21.645: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 561498
*Jan 25 16:05:21.645: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0782
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0080, '910945'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '561498'
*Jan 25 16:05:21.713: ISDN Se0/3/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8782
*Jan 25 16:05:21.717: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8782
Cause i = 0x80B4 - Service operation violated
*Jan 25 16:05:21.721: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0782
*Jan 25 16:05:21.781: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8782
Cause i = 0x8090 - Normal call clearing
*Jan 25 16:05:22.917: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 910945
*Jan 25 16:05:22.921: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 561498
*Jan 25 16:05:22.921: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0783
Standard = CCITT
*Jan 25 16:05:22.981: ISDN Se0/3/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8783
*Jan 25 16:05:22.989: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8783
*Jan 25 16:05:22.989: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0783
*Jan 25 16:05:23.041: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8783
*Jan 25 16:05:24.189: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 910945
*Jan 25 16:05:24.193: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 561498
*Jan 25 16:05:24.193: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0784
I attach you the configurations of site A and site B
thank you.
Paolo Bevilacqua Fri, 01/25/2008 - 15:52
Hi, really you should ask PBX people why the call is rejected, because the setup seems perfectly valid. You can compare it with a setup from B or C, to A.
By the cause, it seems like incoming calls are blocked.
Can site A call site B ?
dbenattou Fri, 01/25/2008 - 16:42
hi,
thank for reply.
Site A can call site B, and one thing that i have forgotten to say last time is that when i simulate the call from the router with "csim start 561498" command, it works and the call passes.Also, the call from Site C to Site A passes succeffully
i send you the attachement of two calls : one from router and the other from phone behind PBX that i have token from the Router-SiteB
Regards.
Paolo Bevilacqua Sat, 01/26/2008 - 02:50
On router B, take a q931 trace of the csim call that works, to compare with the one that does not.
The only difference should be the calling number, none in case of csim.
If this is true, as a workaround we can try changing the calling number.
Do not take ccapi debugs that are not useful in this case.
dbenattou Mon, 01/28/2008 - 07:20
hello,
you find below the trace of the call that works, dipslayed in Router B
Jan 28 10:23:01.761: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0077
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Channel ID i = 0xA9838C
Exclusive, Channel 12
Calling Party Number i = 0x0083, '1498'
Called Party Number i = 0x80, '910941'
High Layer Compat i = 0x9181
*Jan 28 10:23:01.781: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8077
*Jan 28 10:23:03.425: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8077
Progress Ind i = 0x8588 - In-band info or appropriate now available
*Jan 28 10:23:07.205: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8077
*Jan 28 10:23:07.257: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0077
*Jan 28 10:23:13.201: %ISDN-6-CONNECT: Interface Serial0/3/0:11 is now connected to 1498 login local
--More-- line vty 5 15
--More-- password 7 *********
--More-- login local
scheduler allocate 20000 1000
end
*Jan 28 10:23:24.733: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0077
*Jan 28 10:23:24.733: %ISDN-6-DISCONNECT: Interface Serial0/3/0:11 disconnected from 1498 , call lasted 17 seconds
*Jan 28 10:23:24.733: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8077
*Jan 28 10:23:24.797: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0077
thanks.
Paolo Bevilacqua Mon, 01/28/2008 - 07:27
you said that site A can call B, but not C.
The trace you have sent is for a call from B or C to A, we knew already that is working.
Now since it appears B is blocking calls from A to C, but whit csim start is works, you can try resetting the calling number, the easier way is "clid network-number XXX" in DP. Try placing some number that belongs to B.
dbenattou Mon, 01/28/2008 - 17:33
the trace that i sent you regards the call from 'A' to 'C'.
Now, all the calls from and to all sites works, except the call from A to C.
I don't understand what's clid network-number XXX and which site must accept this command.
thanks.
Paolo Bevilacqua Tue, 01/29/2008 - 02:08
maybe you took the tace on A, because it is an incoming call. If it was taken on B, for a call from A to either B or C, it would be an outgoing call.
The command goes under dial-peer. You need to verify that on B, you reproduce the same parameters as for the "csim" that works.
But it is only a worjaround. Only the PBX people can tell you why your call is not accepted.
Now before you say that I understand they is possible that they don't answer/don't know/cannot be asked, etc.
pcameron Tue, 01/29/2008 - 04:20
I think the problem is not related to calling numbers.
Here is the original Q931 setup message that fails -
Standard = CCITT
Here is the inwards Q931 setup message that works -
Standard = CCITT
The difference is in the bearer capability. The failing call has a bearer cap of 0x9090A3 - 3.1khz audio. This is for 'speech', but in the past, this was generally used for conditioned fax services.
The working call uses a bearer cap of 0x8090A3, which is 'normal' G711alaw. For whatever reason, it looks like the PBX can't handle the 3.1khz bearer capability.
I can't help noticing you have the following configured under the D channel on Router A and B -
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
This command is going to overide the outgoing bearer cap on both routers, so first thing you need to do is remove it and try the test calls again.
Second thing you need to do - add 'network-clock-select 1 e1 0/3/0' on router B. You might not have noticed it, but the E1 on router B would be seeing incrementing clock slips. Do a 'sh controller e1 0/3/0' before and after the you have added the above command to confirm the clock slips have been cleared.
