IPIPGW SIP to SIP codec negotiation problem.
Jan 25th, 2008
I have a strange problem with an IPIPGW configured for SIP-SIP.
My setup is as follows:
CCM-----SIP---IPIPGW(2801 IVS image) ----SIP------SP huawei x3000 softswitch
If i configure a codec class as follows
voice class codec 2
codec preference 1 g729br8
codec preference 2 g729r8
for both dial-peers, call works ok as the gateway negotiates g729 on both sides.
If i configured a codec class as follows
voice class codec 1
codec preference 3 g711alaw
I get one way audio as the CCM side is negotiated as g729 and SP softswitch side negotiated as g711. (no transcoding configured). SIP debugs shows the following:
923840618: Jan 25 18:16:20: //6193775/72A534369041/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
923840619: Jan 25 18:16:20: //6193775/72A534369041/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
923840620: Jan 25 18:16:20: //6193775/72A534369041/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
923840621: Jan 25 18:16:20: //6193775/72A534369041/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
why does SIP sipSPIDoAudioNegotiation select g711alaw and my codec class prefers g729.
I need this step so that i can carry voice as g729 to g729 and fax as g711 to g711 without transcoding. I don't have enough resources to transcode all voice calls.
thanks in advance
Paolo Bevilacqua Fri, 01/25/2008 - 11:28
for IP-to-IP calls, just configure "codec transparent" under DP, and let the endpoints negotiate.
solomonthuo Sat, 01/26/2008 - 01:54
codec transparent doesn't work for SIP to SIP as per documentation. I also configured it but once the user picks up the call disconnects.
Paolo Bevilacqua Sat, 01/26/2008 - 02:41
Well, then point me to the documentation, because I have it configured for sip to sip, and it works fine.
solomonthuo Tue, 01/29/2008 - 00:55
i was referring to the following document
"Cisco Multiservice IP-to-IP Gateway Application Guide"
Cisco IOS Release 12.4(11)XJ2
pg 27.
Paolo Bevilacqua Tue, 01/29/2008 - 02:16
I shall contact cisco documentation team, because that is what I use, and it makes sense to me.
