Unity 4.0(5) - Status Monitor web page
Jan 25th, 2008
I have Unity 4.0(5) no patches installed TSP 8.1(2)
everytime I try to launch the status monitor web page.
I get the following error
Error: XML fetch failed -- possibly a problem with AvXml.dll or its permissions.
Check that the "AvXml" virtual directory settings in IIS have proper permissions and allow execute access.
Please see the Troubleshooting Guide for details.
Could you please point me on the right direction
thank you
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 01/25/2008 - 17:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Cris,
Hope all is well with you! I found this Thanks to Gonz from Cisco (Thanks Gonz!)
CSCed44345
StatusMonitor: Fails to open and posts XML fetch failed StatusMonitor: AvXml error during page refresh
Symptom:
The StatusMonitor displays an 'XML fetch' error (see XML_error
attachment).
Conditions:
This problem occurs when viewing a page in the Cisco Unity
Status Monitor web application. Nothing was pressed when the
error was displayed...the Status Monitor was refreshing the
page contents according to its usual behavior.
Workaround:
There is no known workaround.
CSCeb28105
Release-note:
Symptom: The HTML Status Monitor fails to open and is redirected to an XML Fetch
Failed error page that tells the user to verify the permissions on the AvXml.dll.
Condition: This may happen if the authentication settings are not configured
correctly in IIS.
Workaround: Go to the Cisco Unity Installation Guide to be sure your
authentication is configured correctly. One key thing to note, is that in IIS
the authentication settings for Web, SAWeb, Status and StatusXml should all be
the same. If one is set to anonymous access, they should all be set to
anonymous access. If one is set to Integrated Windows, they should all be set
to Integrated windows authentication.
http://www.ciscotaccc.com/voice/showcase?case=K74943158
Hope this helps!
Rob
