CatOS command for trunking
Answered Question
Jan 25th, 2008
What command is it to display what vlans are permitted over a trunk port, tagged, etc. And what command is it to set a vlan over a trunk port?
I can do this in IOS but need to know in CatOS.
I need to allow vlan 100,200 on this port.
Correct Answer by ankbhasi about 9 years 1 month ago
Hi Sparky,
You can use command "show trunk" to get the status of all active trunking ports. To get the details of all allowed vlans on trunk port issue a command "sh trunk detail"
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/sh_ti_tr.html#wp1028168
To add the vlans on existing trunk port use this command "set trunk
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/setsy_tr.html#wp1166564
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 01/25/2008 - 11:12
Hi Sparky,
Ankur
dballard99 Fri, 01/25/2008 - 12:27
show vlan trunk will display vlan and ports allowed.
set trunk
example: set trunk 5/17 on dot1q
dballard99 Fri, 01/25/2008 - 12:30
set trunk
or
set trunk
