%OSPFv3
HI
what is the reason on this Msg:
*Mar 1 01:36:46.855: %OSPFv3-5-ADJCHG: Process 1, Nbr 1.1.16.16 on Serial1/0 from EXSTART to DOWN, Neighbor Down: Too many retransmits
R3#
*Mar 1 01:37:46.855: %OSPFv3-5-ADJCHG: Process 1, Nbr 1.1.16.16 on Serial1/0 from DOWN to DOWN, Neighbor Down: Ignore timer expired
How to fixed?
10xs
Overall Rating: 5 (3 ratings)
Edison Ortiz Fri, 01/25/2008 - 12:00
  • Hall of Fame,
    Founding Member
Hi Ali,
Can you post the config from the 1.1.16.16 and this device?
Are these switches or routers?
__
Edison.
ankbhasi Fri, 01/25/2008 - 12:14
  • Cisco Employee,
Hi Ali,
With your brief description and message to me it looks packets are getting lost somewhere due to congestion between the links or some errors on the interfaces or something and is the reason there are multiple retransmissions and adjancy is breaking down.
Was it working fine earlier and you got an error now? I am just asking this to rule out if there is any config issue. If it was working fine earlier can you check if there are any errors noted on the interfaces.
Ankur
Edison Ortiz Fri, 01/25/2008 - 12:45
  • Hall of Fame,
    Founding Member
Right, I understand 1.1.16.16 is the Loopback Address. OSPF uses that as RouterID. I was referring to the device holding that IP. I need to see both configuration as it can be anything, as Arul pointed out.
My first reaction could be a MTU issue or problems with the link.
More information regarding this network is needed to make a formal suggestion.
__
Edison.
ajagadee Fri, 01/25/2008 - 12:18
  • Cisco Employee,
Ali,
"Neighbor Down: Too many retransmits", this basically means that the router that you captured the logs from is sending Exstart packets and is not receiving a response from the remote side.
There could be many reasons, Duplicate Router IDs, MTU, etc. Was it working before or is this a new set up. Can you provide some more detail on this.
I am also enclosing couple of URL's that you should find useful while troubleshooting OSPF.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800949f7.shtml#trouble_mtu_check
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml#exstart
Arul
** Please rate all helpful posts **
Edison Ortiz Fri, 01/25/2008 - 12:46
  • Hall of Fame,
    Founding Member
Ali,
Same theory as OSPFv2. Follow Arul's advice.
__
Edison.
