vpn site-to-stie w/wpn clients
Jan 25th, 2008
I inherited an issue with a site-to-site vpn connection. It's looks like below w/nat being done on r1 for the pix. The vpn clients can connect but the site-to-site won't come up. To compound the issue R1 has two internet connections so policy routing is being used. Any assistance would be greatly appreciated.
Pix--R1--Internet--R2--checkpt
I've attached pix, router, and isakmp debug.
thanks.
Josh
ajagadee Fri, 01/25/2008 - 12:44
I see that the isakmp gets stuck in the below state, which could be something to do with the PSK>
69.25.174.245 172.16.200.1 MM_KEY_EXCH
Can you make sure that the preshared key is matching on both the sides.
Arul
** Please rate all helpful posts **
jestoner7 Mon, 01/28/2008 - 07:11
thanks Arul, the keys do match. The tunnel works when I take out the nat-traversal command, but when added back the far end still see me trying port 4500 to connect.
