Lost remote connection while Telnetted into CSS
Jan 25th, 2008
I have two CSS in a failover ocnfiguration. While I was RDP'ed into a workstation i use to manage them, I lost my remote connection while telneted into CSS-A. Now when I try to telnet back in it says "Maximum Telnet sessions reached" and won't let me in. I can however still get into CSS-B which I forced to be the master for the time being. Is there a command I might be able to launch from B to A that will force a reboot or reset connection statistics?
Dave
Gilles Dufour Mon, 01/28/2008 - 02:55
  • Cisco Employee,
I believe we had some issues with file descriptor being lost.
If you are not running one of the latest image, you should plan an upgrade.
Gilles.
