Cisco 851: cant' hit my internal web server inside of LAN
Jan 25th, 2008
Setup: Cisco 851 connected to DSL line and a couple of inside clients along with a webserver, all inside my LAN.
Problem: I can hit my internal website fine outside of my LAN, but inside of my LAN I can't... I was using a consumer grade LinkSys router before and had no trouble geting to my website inside and outside of the LAN... I know this is probably just a configuration issue on the 851.
Please help!
~Brian
robert.horrigan Wed, 01/30/2008 - 09:37
Are you running a proxy server? You may have to click they bypass for local addresses. Can you ping your webserver? If not you may want to post your router config.
